I installed the US Car Tool core support today and fit great with just a little grinding. I order it without the holes as I like the original look. Next to the subframe connectors and torque boxes it is one the best stiffener you can add to a Mopar! I ground down and radiuses the weld so it would look original. You could jack the car up from the core support now! Thanks Pat
