FYI can’t use the legendary rally seats with the standard charger long armrest. The side bolster Hits the last 2 inches of the armrest. It could work but eventually would leave a dent in the seat fabric. Not a problem if you’re also replacing the door panels but if you reusing your door panels they will be an imprint from the longer armrest base. Thanks Pat
