Re: Modern Bullitt build
[Re: DynoDave]
#2778261
05/26/20 08:21 AM
05/26/20 08:21 AM
Posts: 676 Maryland
Keepat
Maryland
So much cool stuff!
But I think I like the thick blocks of foam for laying on the best! Back and knees saver;-)
[Re: Keepat]
#2785897
06/15/20 11:34 PM
06/15/20 11:34 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I Installed the passenger side rear window and trim. The AMD quarter glass was a heavy 1/16” taller on the rear 12 inches compared to the original. So I had to sand it down with a DA sander to get the best fit. All of the AMD glass has a rough finish on edge so I use the DA sander starting with 60 grit and working my way to 180 to polished edges that show Your a brave man! last time I was "polishing" the edge of tempered side glass with a DA, it was going great one moment, then the next the glass just sort of disappeared from my hand! got a little "gun shy" after that..Lol!...great work as always! Mike
[Re: DAYCLONA]
#2787178
06/19/20 05:10 PM
06/19/20 05:10 PM
Posts: 676 Maryland
Keepat
Maryland
I Installed the passenger side rear window and trim. The AMD quarter glass was a heavy 1/16” taller on the rear 12 inches compared to the original. So I had to sand it down with a DA sander to get the best fit. All of the AMD glass has a rough finish on edge so I use the DA sander starting with 60 grit and working my way to 180 to polished edges that show Your a brave man! last time I was "polishing" the edge of tempered side glass with a DA, it was going great one moment, then the next the glass just sort of disappeared from my hand! got a little "gun shy" after that..Lol!...great work as always! Mike Mike, Working with tempered glass is never fun, but as long as you do not let the glass get hot it can work. I would only sand the edge of the glass for about 30 seconds then stopping to let it cool. Thank you! Pat
[Re: Keepat]
#2795666
07/12/20 12:26 AM
07/12/20 12:26 AM
Posts: 1,066 Newton, KS
70B5Cuda
Newton, KS
WOW....that's all I've got. Can't wait to see pics of it on the street
1970 Barracuda B5 6.1 Hemi/6 speed 1969 Charger survivor in R6 383/727-wrecked 12/24/18 1968 Charger in original burgundy paint "Ribeye" 1968 Charger w/ 6.1L, TR-6060, 9" 1968 Roadrunner w/ 6.1L/6 speed 2011 Dodge Ram w/ 6.7L
[Re: UCUDANT]
#2796553
07/14/20 02:41 PM
07/14/20 02:41 PM
Posts: 4,679 Wichita
GY3
Wichita
TOO PERFECT!
I would be afraid to drive it!
[Re: 70B5Cuda]
#2798300
07/18/20 01:05 PM
07/18/20 01:05 PM
Posts: 676 Maryland
Keepat
Maryland
WOW....that's all I've got. Can't wait to see pics of it on the street Me too! Thanks!
[Re: GY3]
#2798302
07/18/20 01:07 PM
07/18/20 01:07 PM
Posts: 676 Maryland
Keepat
Maryland
TOO PERFECT!
I would be afraid to drive it! I’ll drive it! Thanks! Pat
