The Gremlin Engine: 440 block with ARP studs, stock steel crank, 440 source H-beam rods, .060 over Venolia flat-tops, .053 in the hole, .055 Cometic HG, 10.6 to 1 compression. Indy 63cc 440SR heads tall port with Isky 1.5 ductile iron rockers. Indy 440-3 with 1050 ultra HP Dominator. Howards solid flat tappet cam 272/639 on 108, Howards edm lifters. Milodon dragster pan with dual pickup and Milodon pump.
Ignition: MSD 7AL2, HVC Coil, MP elect. dist. Taylor wires.
Fuel system: 5 gal. plastic cell. -8 line through Fram HPG-1 filter, and comp 140 electric pump, deadhead 2 port regulator.
