To make a hub, I tossed a regular factory rotor in the lathe and cut off the braking surface. After that, I turned down the outer diameter of the hub so it would fit in the rotor.
Once that was done, I put a used Mercedes rotor in the lathe and opened up the center register to fit over the hub. Massaging the bolt holes in the rotor left me with a usable rotating assembly.
To fit it to the car, I had to figure out where that monster rotor could sit and clear everything. It turns out there was only one place it would fit and I've got a little under 1/2" of clearance.
After figuring that out I grabbed a spare spindle and chucked it in the bench vise. A little chunk of 2x4 wood became my caliper bracket. I hacked it up until the caliper fit the new rotating assembly. When the parts fit, I stuck a chunk of steel in the vertical mill and copied the wood mock-up.
When doing something like that you have to know where EVERYTHING fits and make sure that there is no contact when the suspension moves and you turn the wheel.
Having a laths and mill at home isn't necessary but it sure makes it easier to build stuff.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind.
- Stu Harmon
