Re: Post your custom front disc brake setups.
[Re: 70Cuda383]
#1076414
09/18/11 11:27 AM
09/18/11 11:27 AM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
hope that helps!
It totally helps. Are you having to space out your front wheels? I saw this is an issue on the fronts with a dakota and viper brembos. I have also read that the caliper position is not all the way on the rotor on the front?
Is this true?
Or is that the bracket that is used on the late model spindle?
I don't know yet I actually only have the brackets right now calipers and rotors are on the way. Then I need to turn the hubs down so the rotor fits all the way on. Once I get it installed I'll know more
That was another thing...the kit, or one of them anyway came with hubs I remember. Not because the same one doesnt work on the differnt spindle, but for that reason....rotor fit. I'd like to leave my hubs unchanged so if I kill a bearing *which is known to happen with these things) I can hippety hop on down to the parts store and be back in business without a trip to the machine shop. but maybe I have no choice...
[Re: POS Dakota]
#1076415
09/18/11 11:30 AM
09/18/11 11:30 AM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
To make a hub, I tossed a regular factory rotor in the lathe and cut off the braking surface. After that, I turned down the outer diameter of the hub so it would fit in the rotor. Once that was done, I put a used Mercedes rotor in the lathe and opened up the center register to fit over the hub. Massaging the bolt holes in the rotor left me with a usable rotating assembly.
To fit it to the car, I had to figure out where that monster rotor could sit and clear everything. It turns out there was only one place it would fit and I've got a little under 1/2" of clearance.
After figuring that out I grabbed a spare spindle and chucked it in the bench vise. A little chunk of 2x4 wood became my caliper bracket. I hacked it up until the caliper fit the new rotating assembly. When the parts fit, I stuck a chunk of steel in the vertical mill and copied the wood mock-up.
When doing something like that you have to know where EVERYTHING fits and make sure that there is no contact when the suspension moves and you turn the wheel.
Having a laths and mill at home isn't necessary but it sure makes it easier to build stuff.
[Re: POS Dakota]
#1076416
09/18/11 11:44 AM
09/18/11 11:44 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
you'll either have to turn every rotor to clear the hub when you need to replace rotors, or turn the hub and replace it.
or, turn the hub, and when the bearings go out, replace just the bearings. it is easy to swap the whole hub since that's how it was designed, and entire hubs are available for sale, but you can also get just the bearings and replace them, keeping your hub.
I'm going to try to do mine on the "cheap" and with the hub mounted, use an angle grinder to remove metal while turning the hub as the grinder makes contact. might take me an hour or so per hub, but it's "free"
unless I find someone who can turn the hubs down for cheap, like $40 each. then it might just be easier to have them do it.
**Photobucket sucks**
[Re: feets]
#1076417
09/18/11 11:46 AM
09/18/11 11:46 AM
70Cuda383
Marysville, O-H-I-O
trying to picture what you did...so you cut an entire rotor down so it became your new 'hub'? have pictures at all?
if you wear out a rotor, what do you have to do? grab a new one out of the box and bolt it on? or do more lathe work?
[Re: feets]
#1076418
09/18/11 11:49 AM
09/18/11 11:49 AM
POS Dakota
detroit, mi
Yeah, I dont have a mill or a lathe. I wish I did. Someday! But I do have a router table! I can make a wood or acrylic proto and wnen it fits, I can have it copied at a machine shop.
I have lots of acrylic. probably better than wood for making a proto like that.
Good thought, and that I can do.
[Re: POS Dakota]
#1076419
09/18/11 11:52 AM
09/18/11 11:52 AM
70Cuda383
Marysville, O-H-I-O
That was one of my thoughts on it too, and another thing is I am running a 28 inch tire out back with a smaller tire in front, so it might be of benefit. One of the things I have to know is if I can look at it, or if it even bothers me.
yea, you can run a big tire up front, and I prefer wide tires up front for turning and braking, to go with my wide tires in the rear for acceleration.
I like to use as wide of a tire that I can fit...within my budget too. my 275/55s are a tad too tall for me though. I want 275/50s at 28" tall. if I can't find them in my budget, then I'll be going with the federal 255/55s, stock size, 28" tall, and just over $100 a tire.
[Re: POS Dakota]
#1076420
09/18/11 11:52 AM
09/18/11 11:52 AM
feets
Senior Management
Senior Management
Irving, TX
Look at that again. You haven't even mounted the tires on wheels and you've already got a road kill! Seriously though, tires are a big part of a brake upgrade. I went from 235/60-15 and 275/60-15 BFG Radials with S speed ratings to 245/45-18 and 295/45-18 Nitto NT555s with W speed ratings. There is a WORLD of difference. Stopping, starting, and turning ALL greatly improved with the tire change. I had them on the car before I installed the new brakes. Attached is a pic of the car with 11" disc brakes and the new rolling stock. As for your rear ABS taking up the slack, remember that the ABS works great but it also dumps lots of heat in those brakes. They'll work fine for a while but if the brakes can't dissipate the heat they'll lose stopping power. That's one idea behind large rotors. Not only does the larger diameter give you a longer lever arm but it also means more surface area to spread out the heat. My rotors (and Ozhemi's since he used the same thing) weigh 27 lbs each. That's HUGE. However, I have not been able to overheat the rotors with enthusiastic street driving or lots of brake boosting on the highway.
[Re: OzHemi]
#1076421
09/18/11 11:55 AM
09/18/11 11:55 AM
POS Dakota
detroit, mi
Cut them out, then just cut out and welded on the legs/spacers you can see in the picture above to give it them the correct spacing away from the spindle and was good to go
OZ, what did you use to cut that steel? I'm assuming a mill. If I bought a high speed carbide cutter, I wonder if I could use a router very carefully so not to fry it. I have a few routers that have pretty strong motors in them. I already have a few carbide cutters that would work. hmmm...
[Re: feets]
#1076422
09/18/11 12:00 PM
09/18/11 12:00 PM
POS Dakota
detroit, mi
hehe those are alaskan malamute hooves. She's never too far away.
Good thoughts on the ABS.
The beauty of this truck is every last ounce of computer controlled "goodness" is gonzo! No more ABS, no more efi. I am fully in command.
The ABS and EFI in this truck were horrible to work with and drove me nuts. I will not be reaching any kind of crazy speeds as I am using a 727, so I dont think I need anything necessarily exotic for tires, but yes, the footprint is important. I want it to stop, not slide. A good hotrod can stop as well as it goes, and when it rains, not be crippled to 45 mph on the highway with everyone shooting you the bird.
[Re: feets]
#1076426
09/18/11 12:18 PM
09/18/11 12:18 PM
feets
Senior Management
Senior Management
Irving, TX
The lathe is a bit heavier and a more interesting to move around. I used my brake upgrade as an excuse to buy it. It's come in handy for all kinds of stuff but I'm a tinkerer by nature.
Here's the Pratt & Whitney when I got it home.
[Re: POS Dakota]
#1076427
09/18/11 12:22 PM
09/18/11 12:22 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
I wish I had a mill... Just used a combination of air cut off tool and a sawzall (for the rough cuts)
I do have alot of tools, but a mill is not one of them
To smooth it all, I used my Oz-made multi-tool...basically a belt sander sorta thing made for metal that uses all sort of different grade belts. (It mounts to a bench grinder motor) I use it constantly for everything...a great thing I bought many years ago.
Oh, and on the rotors...since I went with 5 on 4.75" bolt pattern I needed the rotors redrilled. Which is no big deal and when the time ever happens to come I need to replace them will just get it done again. My car is quite light though so figure the rotors should hold up for a while perhaps.
Looking back, I probably could have just got another set of hubs made in Mercedes bolt pattern and had that drilled when I made the wheels. (so could have used off the shelf rotors) Not like I am going to rotate the tires on the car
I would like to someday run (just for the heck of it) the same 8 piston calipers as Feets has...just need to wait for a deal on a pair.
[Re: OzHemi]
#1076428
09/18/11 12:34 PM
09/18/11 12:34 PM
POS Dakota
detroit, mi
The fit and finish of the brackets really had me fooled. I was under the impression you had a mill and lathe too. Nope, just lots of work ethic...just as good! Takes a little longer, but the end justifies the means.
Phew! I dont feel so alone now!
[Re: POS Dakota]
#1076429
09/18/11 12:35 PM
09/18/11 12:35 PM
OzHemi
Garden Grove, CA
hope that helps!
Is this true?
With having to space the wheels out..
That is where I took some time with checking alot of measurements. (And got lucky that feets had alot of Benz ones laying around to measure too ) I checked around on rock auto a bunch to sorta start with since they have rotor sizing for most of thier part numbers. I just tried to think of cars that came with big brakes and started checking
My first "easy" idea was to use 14" Z06 Corvette rotors...but they were way too 'flat' and not enough rotor height to have the caliper clear the spokes in my wheel.
I wanted to run a certain wheel and so just had to build the brake package to suit them. Where as with Feets, we had to build a wheel to fit his brakes
I just got some AP Racing calipers in the mail a couple days ago too and sorta held one up to the front on my car..they are kinda cool looking as well actually...but they are boxed up now and gotta mail them off to a guy in Oz on Monday.
[Re: feets]
#1076430
09/18/11 12:37 PM
09/18/11 12:37 PM
POS Dakota
detroit, mi
"Honey, I'll be right back, I am just running out to pick up a tool I need...."
PFFFT!!!
Believe it or not though, I am seeing all kinds of stuff like that around here for sale, and for cheap. I should look into a vertical mill at a minimum.
[Re: POS Dakota]
#1076431
09/18/11 12:39 PM
09/18/11 12:39 PM
OzHemi
Garden Grove, CA
Thank you...and would be nice to have those other tools, but just have to piddle along with what I do have.
(A nice drill press does help alot, I got one of those ages ago) I've made alot of parts for the Torana build and been happy with how they all came out.
[Re: POS Dakota]
#1076433
09/18/11 12:43 PM
09/18/11 12:43 PM
OzHemi
Garden Grove, CA
PFFFT!!!
Shops going out of buisiness is a great place to pick up a deal on equiptment.
I got my Snap-On mig welder a while back (wow...now that I think about it, it's been about 12 years ) and it was maybe a year old at the time and barely used..it was a tire shop I used to deal with that thought he was going to get into custom suspension work and just gave up on it all after a year and sold all his stuff off for next to nothing.
Sure with how things are going there are plenty of smaller shops around getting rid of mills and stuff too...but my garage is running out of room.
A nice metal cutting band saw would be handy too
And a....
And a....
And a.....
Never ends.
