Ok, I got tires mounted to my front wheels and threw them on the mighty (albeit mostly apart) POS Dakota....
I have about three inches all around my 11.3 inch rotors in there now. from the edge of my clumsy iron single piston caliper, I have what I am going to limit to 1.25 inches for safety. I have some room to work with. I will need a caliper that doesnt stick too far past the end of the rotor and I will clear the wheel with a 13 inch rotor. Definitely a 12 inch rotor from a later model dakota. If I did go with the 12 inch rotor, I think any 4 piston caliper coupled with that would be a lot more stopping power. I'm digging the look though...
