Look at that again. You haven't even mounted the tires on wheels and you've already got a road kill!
Seriously though, tires are a big part of a brake upgrade. I went from 235/60-15 and 275/60-15 BFG Radials with S speed ratings to 245/45-18 and 295/45-18 Nitto NT555s with W speed ratings. There is a WORLD of difference. Stopping, starting, and turning ALL greatly improved with the tire change. I had them on the car before I installed the new brakes. Attached is a pic of the car with 11" disc brakes and the new rolling stock.
As for your rear ABS taking up the slack, remember that the ABS works great but it also dumps lots of heat in those brakes. They'll work fine for a while but if the brakes can't dissipate the heat they'll lose stopping power. That's one idea behind large rotors. Not only does the larger diameter give you a longer lever arm but it also means more surface area to spread out the heat. My rotors (and Ozhemi's since he used the same thing) weigh 27 lbs each. That's HUGE. However, I have not been able to overheat the rotors with enthusiastic street driving or lots of brake boosting on the highway.
hehe those are alaskan malamute hooves. She's never too far away.
Good thoughts on the ABS.
The beauty of this truck is every last ounce of computer controlled "goodness" is gonzo! No more ABS, no more efi. I am fully in command.
The ABS and EFI in this truck were horrible to work with and drove me nuts. I will not be reaching any kind of crazy speeds as I am using a 727, so I dont think I need anything necessarily exotic for tires, but yes, the footprint is important. I want it to stop, not slide. A good hotrod can stop as well as it goes, and when it rains, not be crippled to 45 mph on the highway with everyone shooting you the bird.
