billy, does the gremlin normally sit low in the rear, or is this just the amount of stuff in the box and rack causing this stance ? also, if the extra weight is causing the stance, how much does this affect the shock and spring on the coil overs ? you do a SUPER write up on drag week ! if my health was lots better and i was a bunch younger, i might entertain such a venture. keep up the good work and thank you !!!!
