Quote: This has been a great post to follow. I am looking forward to seeing the final product as well. One question for you; My 6 barrel 'Cuda is an LA car as well and I just took the car off the rotisserie about a month ago after blasting it and priming the undercarriage in the original LA color, which was black/dark gray, not the more common light gray - what color was your car after you stripped of all the undercoating and what color did you go with on the final coating? Here is a photo of mine before blasting and right after cleaning the undercarriage with mineral spirits in order to take some documentation photos. Just curious if your LA car was the same color on the undercarriage? Thanks, Rob
Rob,
Definitely Dark Gray, just like yours. I'll be posting pictures the first of the week.
This one is getting the OEM overspray treatment but with show quality paint on top so, stay tuned for correct primer/sealer and paint colors.
Hey, the owner of the car we are doing is from LI too. You guys will be the unbeatable duo at your local shows.
