Quote: Looks good... should of used a steam pressure washer and been done with under coating removal in one day and had better results. You would have been able to see the factory finish and markings.
Yes and I would think the massive undercoating would actually preserve the finish and paint markings even better.
Maybe ours doesn't have enough pressure but it wouldn't budge the undercoating.
It's not pressure that does the job, it's water volume and temp. Steam is right about 210 degrees and some gasoline to soften up the undercoating. Gas not anything else. Here's the machine I use. 4+ gpm about 1500 psi and will turn the water to steam.
How can you do a factory oe refinish/rebuild for 25K?
