Quote: ... All suspension detailing will be done per factory specs and all OEM inspection markings, etc..
Do you have pics of the factory underside inspection marks you found that were left on this very clean original car??
Um, I don't think I said that it was very clean but I'm pretty sure I did say that it was covered with extremely thick undercoating.
Sorry, in underside I meant front and rear suspension, rear springs, center section...
They covered everything with the undercoating and I mean everything. I'll bet they had to clean the tires off before the car would roll again when they were done. The first guy who did an oil change afterwards must have needed a chisel. So, no.
