Quote: Why do you think the bag is ripped? Remember yesterday when they put up the plastic so noone could see in? Don't you think they ripped it open to see what kind of shape the car is in??
My thought is that the weight and pressure of the water pushing in on it once it filled the vault caused it to tear, and right there at the fin wouldve been the most likely spot if there wasnt enough "loose bag" to allow for that. Put your hand in a plastic bag and then shove it down in a container of water. The bag will immediately try to take the form of your hand. All it would need to cause a leak is a sharp point....like a fin on a car maybe.
