Just to clarify, the car was not burning that much oil. It was needing to add a second quart when I changed the oil just before I sold it. At about 5500 miles. So that is one quart in 2750 miles. By todays standards that seems like a lot, but may in fact be normal for this motor. And it may have gotten better as it broke in some more. I will bet that every one of your Guy's race motors burn that much oil in that many miles (if you should ever drive that many miles with a race motor) and it is not causing detonation. Or basically I do not believe one quart in 2750 miles is enough to cause detonation in this motor. I think that question as to the oil level got some of us off track.
