Ya sounds like Westech just doesn't know fuel injected mopars .
You're kind of missing the point, you shouldn't NEED to compensate problems with the ECU, if it's reading a bunch of knock counts good chance it IS KNOCKING or you have a bad knock sensor... so you fix the problem (burning tons of oil, or replace the knock sensor).
