Gambling over state lines? Well, technically it's not gambling if its a sure thing... more like paying your tuition. Seriously though, put a little thought into it. You don't have to bet on a losing hand. For those that can accept it, here is a neat video on the purposes of needing rotor phasing.
Start watching at 2 minute mark. Shows the advance in action several times after rotor phase being set properly.
Yes. I watched that vid. Almost made me jump back to your winning side as you put it. Don't jump to conclusions from that vid.
Watch it again yourself and consider this. Listen to the rev of the distributer machine.
At 2.00 the rotor starts out at the Left, as it revs, moves to the Right. Mechanical advance right. But wait, as it continues to rev, the rotor sweeps back to the Left and then again to the Right. Then back to the left as the RPM slows again. Done by 2;14
Someone is Clearly just manipulating it and Showing a ideal rotor phase perimeter, As they were doing in that vid.
If it were just a mechanical advance it would of Stayed in its proper direction of sweep in its correct rpm range. Its not going to Sweep back and forth above the RPM the advance is already enacted.
