Mr P, I say it wont move even if the dist is into the weights at idle. That is: if you "freeze" the rotor position with your timing light with the can capped (& that is what the rotor phasing position is) that it will NEVER move from that position no matter what". Would you like to get (further) in on this (only $10 entry fee)!
