they need to take it back & send you a good one. I ain't familiar with those dists but I sure thought it was too good to be true that the reluctor/magnet gap does not change when the can is applied (but if they have solved that then kudos to them). On OE dists it (vac adv) drastically increases that gap (in addition to the RP change) which does affect cyl to cyl timing.
