Made the new hole for the roll pin and filed it out and it fit perfectly and ended up fitting real nice on the shaft, I really hope cw was the right direction to go inn cause of how perfect this turned out. I'm installing the distributor back into the engine now and I'll report back with the findings after I hook up the timing light and watch the rotor.
