I would redrill another hole in the same reluctor, just go to another 45 deg space inbetween another set of teeth. EDIT with a 45 deg spacing on the C to C of a pair of cap bulges, an 11 deg can will swing an arc 1/4 of that distance. Ideally you want the rotor tip to cap terminal tip gap to be the closest at WOT (no/mimimal vac) as the can is retracted & the required voltage to jump the plug gap is the greatest at that point in time (high cyl psi) and the available voltage is the lowest (coil rise time between firings is the lowest at that fast rising/higher RPM) & it takes energy to jump that meaningless gap then what is left goes to the plug.
