So to get the vacuum advance on the distributor to stay pointing at the passenger side fender of the truck do I have to rotate the oil drive gear over a tooth going clockwise or counter clockwise? Every time I've installed the reluctor ccw on the distributor it requires me to turn the distributor so far ccw that it's pushing the vacuum advance into the back of the intake manifold.
