I've had this issue ever since I put this box in my truck and the entire time I thought it was drivetrain related. It could also be the ignition coil it's self though right? I just don't understand how it could be the coil when it appears to ohm out just fine with my multimeter when I check the resistance.
Did it start right when the box was swapped in? & I'm assuming there were other changes done at the same time which would have kept a person from seeing the obvious, that it was the new device, the box. Usually a bad coil that will run, The eng starts to run miss or just dies after it gets warm.
