Quote: Somebody mentioned the 383 can made "gobs' of torque, I assume that the poster implies that is more then a 360, so does 23 ci more from a short stroke motor make that much more torque then a longer stroke motor? Since no one has questioned the "gobs" comment, it's a correct comparsion?
Don't forget the lighter reciprocating weight of a smallblock would be a freebie inherent to the "gobs" that the 360 would have.
BUT, the experts have spoken and it's all moot anyways..............
the OP has the combo already tweaked in his mind and is going to build it to his liking no matter what is said. Which is fine but you'd think we could all walk away sharing ideas regardless.
A cam'd up car with tall gearing will be a fast car but not a quick one. Been there dun dat.
