Talking unrebuilt short blocks here, the 360 magnum wins hands down. A 40 year old cast ringed 383 that lived under a carb all its life versus a moly ringed 360 that lived under a clean running efi system. If you've ever taken apart a high miles carb engine versus a high miles efi engine, it's a night and day difference. The 360 will have better ring seal, cleaner pistons and valves and be easier to get a decent compression ratio out of on a budget. As much as I like big blocks, you almost can't find a good running good condition unrebuilt stocker anymore.
