Quote: New dry sump pan showed up the other day. I had Charlie build me a big pan. We'll see if the exra volume helps to make some power. This pan is really big. It has a 4 inch kickout and a deep belly section.
Is the big pan going on right away, and will you swap pans at some point to see what difference it makes?
