Andy, do you have a good idea about how much power the dry sump is worth, not including the crankcase vacuum(you could get that back with a vacuum pump)?
I guess I wouldn't have thought there would be a 75+hp loss by running a slightly lower CR(13.5-14:1), a more valvetrain friendly cam, 1.7 rockers, wet sump oil system, and a vacuum pump, but I don't remember what you found the dry sump was worth.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
