Quote: I look forward to the DP results. Thanks for sharing.
Let's just say it wasn't a good idea to run the Indy DP on this motor! We lost 100 hp and the EGT readings went wacky. Now I need to pull the plugs and check for damage. I tried it, but in hindsight I should've just left it on the shelf and stuck with the race intakes.
