Carb spacers are just one of those things that you need to try to see how it works. Most engines will gain power with a taller spacer, but it doesn't always reduce the ET. We use 3 or 4 inch tall spacers on the dyno to add power, but in a car that tall of a spacer often causes a stumble unless you add a bunch of volume to the accel pump.
