I would check the cranking compression on all cyclinders, and get in the habit of doing that every outing. Pull all the plugs, block the throttle open, (leave it open for the whole time, just cover with a rag in between tests). Record the first pump, and then what it gets after say 7 pumps. Keep this as a record, and compare every outing.
As i previously told you, this engine will most likely want MORE retard than you or anyone else would expect. Take 2* more out of it, if you have to put a colder plug in just that one hole also. Sawed off straps are TOO MUCH timing period !! Dont forget that
Also , at the first "mis" or "bang"....lift, its not going to "clear up" so dont put more misfires through the pipes than you have to
I was big dumb and forgot it had a NGK BKR6E in it. A projected tip and way too hot.
I bought NGK r5671-8's today for it.
'63 Dodge 330 11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs. 10.01 @ 133mph with a 250 shot of nitrous an a splash of race gas. 1.36 60 ft. 3,700 lbs.
