Pulled the motor back out to install the flexplate. Probably could've done it in the car but it was just a couple of bolts and less than an hour to pull it, install plate and put it back in. The B&M external balance flexplate is SFI approved and eliminates the need for weights on the convertor! I made sure and marked the convertors relations ship to the cutout so it bolted in perfectly.
