I ran the feed line today. Much bigger! It fit nicely along the edge of the rocker underneath the little things that grab the carpet. The 8" or so of braided line that connects to the solenoid stands out way too much so I'll put some black shrink tube on it. I need a -6 bottle nut and a fitting for the pressure sensor and it will be done! I'm considering a 1/4 turn ball valve to keep pressure off the solenoids and shut off the feed line. Looking for a place to conceal that but keep it handy. Maybe up under the dash?
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
