I added an MSD timing controller to pull out timing easily when I use the nitrous. I've been pulling 6° with the 150 shot and want to bump up to 200. The car is harder to start and shut off (wants to run on) with the timing pulled so I would like to be able to do it right before the water box at the track. I grabbed some 2 heat range colder plugs, too!
