Originally Posted By jkgtx
well interesting post as i was the one to purchase this repaired block not knowing it had a hot oil pressure problem,but all is good as it was used and what i was looking for,so after reading i went out and spent some time on the block,,plugged all mains oil passages ,blocked off head feeds,capped off all external places put in a used cam and pressure tested system,as dragula told me has good cam bearings well little soap and water shows i have a problem with rear cam bearing ,removed rear plug and put cam in back side has double the clearance as front bearing, is this the possible issue i would hope as i will rebearing cam and put together a 572 this winter after doing for checking into the block. i hope all works out and am happy to have a long awaited hemi block
The cam bearing is interesting...
I had a number of shops look at it, and none of them found any issues with the block itself, but they did find issues with our oiling system. We suspected this is why we lost a rod in the first place and repaired said oiling issues. But, time and time again, it was checked and nothing in the block was found, yet we still lost pressure only when hot. After months of getting no where, I finally decided to go and just buy another block and see....We put all the same parts in that block, including our oiling system, and no issues other than my carb went a lot leaner with this one.
It sounds like you found more than we did. I paid a lot of money to different shops to look at it. Not to mention my time putting it in and taking it out of the car probably 10 times. I really wanted to believe we had a bad oiling system or somthing not related to the block, but if you found somthing, that's a good thing...We never found it.
'70 Cuda,...605 EFI Hemi Street Car (6.20 best pass, 1.33 60ft)
https://www.youtube.com/watch?v=WYw6RA-k5Bk (6.25 at 108.75mph from inside car)
https://www.youtube.com/watch?v=3zQEb9uxFng (6.25 at 108mph from outside car)
'66 Barracuda AWB Stretched nose Blown 440 Car in build stage
'71 Duster Drag Car 400 Low Deck 512 best 6.002 at 115.44mph
https://www.youtube.com/watch?v=Znuo3jMUXTk
