From the cam delema, we went on with what to do about the block feeding high pressure oil to the accumulator. Needless to say we called a few folks, but were never able to make the accumulator work with the port we were using on the block. We gave up and blocked off the port, and I pulled the accumulator out of the car....Subtract another 20lbs.
Next up, was sealing every nook and cranny on the engine. Spent at least an hour with a tube of RTV making sure all the leak points were sealed.
Next, I am not sure I covered the oil pan delema. I had a Milidon on order, it never showed up. I ended up gutting my pan to clear the stroke. Scrapper and windage tray were cut out. I tweaked it some more this winter and added a scraper that we sandwiched in there instead of the welded one that was in there for a 4.15 stroke. We also found the swinging pickup sticking and fixed that as well.
'70 Cuda,...605 EFI Hemi Street Car (6.20 best pass, 1.33 60ft)
https://www.youtube.com/watch?v=WYw6RA-k5Bk (6.25 at 108.75mph from inside car)
https://www.youtube.com/watch?v=3zQEb9uxFng (6.25 at 108mph from outside car)
'66 Barracuda AWB Stretched nose Blown 440 Car in build stage
'71 Duster Drag Car 400 Low Deck 512 best 6.002 at 115.44mph
https://www.youtube.com/watch?v=Znuo3jMUXTk
