Did you guys over there at AFCO ever get those reducer bushings for your front double adjustable shocks. The lower bolt holes are too large for stock front ends on these mopars.You needed to get reducers to put in the lower hole to make the stock bolt work with your shocks.
I'm in the market for another set of double adjustables
