eric, i have problem that only a few on this board can relate to.
on my dragster, 4 link rocker arm setup, with the (apparently) first generation afco shocks.
the car worked really good with previous owners setup 565 bbc and glide, mine is a 499 mopar/glide.
the car 60s pretty consistent, but the 60-330 #s change. when the track is hot and slick it actually runs quicker. i jetted the carb up and rulled out fuel. lowered top bar in the front with no change.
ideas on shock adjustments here, or replacement of shock is possible.
my ideas for this spring, move battery out of nose, to put more weight on rear tires, raise launch chip from 4600, add more rear gear from 4.10 to 4.29 to hit tire harder.
any ideas appreciated.
