i am sure i can, will have to try it when i get it out, i do see what you and everyone here is saying. actually to much bit for the setup. if you tighten the extension on the shock would that help, or make unmanagable?
You normally tighten it on a good track and soften
it for a bad track so in your case maybe that would
help but I cant see it doing much down track so I
will let someone else like Eric make comment on that
