Quote: Awesome work! Im going to start collecting parts tonight for my 76 D200. Ill be incorporating them into my existing airride suspension. Has anyone went low enough that they have had to pie cut the upper control arm and roll the upper ball joint for better angle?
dont think thats necessary unless you were running huge rims/tires. only thing i did to my truck was cut 1.5 coils out the front and the strut rod mounts are only bout 5" off the ground. with proboably just bags you could lay these things out, deff no probs if you used bags and spindles. another possible issue is the pitman(?) arm on my truck is only about 1/2" away from strut rod now. the rear will reguire c-notch though i believe. still need to get tires/rims for mine though, and maybe try to go lower in the rear. bags in the future
