Quote: 85 Ram thanks for taking the time to measure your sleeves.I just left the parts store and its looking like the c-body sleeves are going to be perfect.85 Ram I actually had a set of your sleeves in hand at the store but they were too long.The Moog book shows 9.66". They took up all the adjustment in the tie rod ends.The c-body sleeves are 8.12" and should be fine.Moog part # ES440S.They are .687 on the adjustment end.Same as van and Ram sleeves.Here is the kicker no one in town has them in stock.They will be here at 7:30 tomarrow morning.The guys at O'reilly gave me a Moog master catalog I can cross refrence everything at home now.That was super cool of them.This is getting close fellas.
I wonder what else is different because i tell ya, looking on mine, it looks if i flip the tie rod to the bottom side for those spindles that i would still need to lengthen my sleeves on my truck. Maybe there is alot more different between a '73 and an '85.
