Quote: I am picky there is nothing wrong with the spindles that would cause them not to work but there is a few things that I don't like about them. The spindle is not centered exactly, that will cause the bearing seal to be off center. The tie rod holes are not drilled exactly in the center of their bosses. So with that said the spindles are fine to use I just like everything to be right.
OIC I am the same way when it comes to things like that.
1975 Ramcharger 6" lift 35" Mud Terrains 8 lug 44 front, 60 rear. (R.I.P.) 1976 D100 lowered 3" & 5" Now with a 440!!! (sold) On the hunt for another beauty to build.
