Quote: Ok,I just bought a new camera today so I hope this works.First of all I want to say that my truck is a 73 model but I think all that changed on the later trucks was the inner wheel bearing.As ball joints are a non issue same as Dakota (5 ft cheater pipe to remove upper).The first obstacle is the dust sheild,which you will see in the pics I still need to modify a bit.The Dakota spindles move the caliper down a couple of inches so there is some trimming envolved and also drilling new holes in the shield.
'87-96 Dakota share balljoint with some trucks. They did change on some. Same are as follows lower ball joints- D100 '72-79 and '83-89 D150 '72-80. Upper - D100 '72-79 '83-89 D150 74-93 those are the same.
