... now that im out of the research and development stage....
Hey Cheeto I in no way meant to downplay what you have done to help out on these trucks.Ive read the boards and you are a pioneer when it comes to lowering these trucks,and for that we are thankfull .My R&D stage was mainly figureing out how to keep my small bolt pattern. No machine shops wanted to turn these spindles down to the smaller inner bearing size.And if they would do it it was pretty pricey. So I had to find rotors with 4 1/2 pattern and the larger inner bearing.I ended up with 76 new yorker rotors,they bolt right on to the Dakota spindles. Tie rod ends today (hopefully)
