Quote: I need some info if you SS guys can help me out. What compression are the SS motors making in 04-05-06. I have a SS motor just had it freshend up and installed all new pistons and i think the compression is off.
Rob
the dome is 105, the chamber is 168, whatever it comes out to. I think it is 13 something. we work on cc specs, and try to max it out. I think you had the booker motor didnt you? probably had a small dome as is usually the case with brand "B" motors.
I cant believe the normal tech expert didnt jump on that one, hope that helps. cw
hemimilita.com
We are racers, not daycare providers.
