you can try the big stop 18 degree?? and stiff springs to slow down the advance to come in later. everything in this game is trial and error to get it best!
Of all the things you've tried and learned how to do, this seems like it would be the easiest and least expensive and most likely to help your problems. Hang in there! After all this, I need to hear a sucess story and that you were able to ride off into the sunset and
