Quote: They had a class like this at one time...it was called Pro Nostalgia and I wish they would bring it back. Heads up!
What was the weight class and what restrictions did they have in order to run...?
They could run holley carbs,10.5w tires, trans break,heads up. They had to weight lbs per cu.in. based on type of head and manufacture. They weighed between 3000.-3400 lbs. The last year that that class ran they where running 8.70-9.00's
What yr was the last yr they an that class? How many cars were in that class? Was the class A,B & E bodies?
