Quote: I did not know you could set a record in NSS racing ? I have raced with a few and I ran in an 11.50 index class (had to dail every 1/2 second) and another that you have to dail on a 0 you know like 10.80 or 10.90 so I just did not know the system even has a way to set records ? I assume the Ford is just the fastest car running the class as I would think its the blue Falcon running with the 422 club ? Ron
NSS Really has very little restrictions....... Any cubes, wt, compression,valve sizes,heads mods are not controlled and carb rules are liberal...... It is not regulated enough for evaluating performance to regulated specs, like NHRA/IHRA Stock/SS. The cars are cool and the series is good........
