Quote: Look ate these cars from the outside they look like the 60's. Look under the hood it looks similar... what more do you want?
Casey
I know when my Grandpa bought his new '65 Coronet, he was able to run right down to Sheffler's in New Castle, PA and order new Weld Pro Stars, ladder bars, Strange Coil-Overs, a PPP shifter, and Indy heads to go racing with. Then he went over to Superior Sign for new vinyl lettering on his $5,000 base/clear paint job. Yep, all that in 1965...
You know what I meant lets say they "resemble" the past, better? Maybe we should all go back to leaf springs and iron blocks. Only things you could get back then......
