Quote: Maybe you guys should re-think the trie sizes a little.,....
LOL 14 X 32 ????
Maybe you go a lil faster if you have less rotating weight back there.
This is 2011, people are going in the 7's and 6's on 9 and 10" tires
Oh yea thats right it Nostalgia Super Stock....supposed to be the 60's
Well I'm not as fast as those guys but I've always run a 9 x 28 tire. Look at all the Stockers that are flying with the 9 x 30 mandated tires too. I see no reason to drag around all that tire in high gear.
Paul H tested 29.5, 31.0, 33.5 and was the quickest on the 29.5's
Casey what gear you guy run in your car? I have Mike Bookers old MW center section from his SS/AH cuda and they had 5.60 gears... I don't plan on buzzing the motor that high but I'm thinking a 4.88 might be a good starting point...
Hi Rob, We run 4.56's go through the traps at 7500
Tunnel ram OK in NMCA but it all must fit under a 5" hemi/MW scoop. poppaj
AA/NSS 65'Coronet "Whompin Wedge" Pop & Son Performance 557" B-1 power John Holt Chassis
