Quote: Actually I have been wondering about the B-1 stuff in NSS for quite a while. So with the wording of the rule as per 1.17 with any internal modifications can't you guys run M/C's? After all is is the same casting. I guess is all up to interpretation. Thank you for clearing that up.
Whats up Dap? There are a few guys running B1 heads in NSS... They wont let the TS or Preditor heads run...
Actually as far as I know we have the only B1 NSS car running at the moment. Dap your right we could run the M/C no problem, in fact could run a PSO head
Casey
I wasnt aware of that Casey that you guys were the only ones running a B1 head... Id figure if it was legal to run a lot more guys would run them since you can make some big power with B1 heads... 2012 should be a good yr for the NSS cars since more racers are stepping up there program...
NoJoke let me get this straight....YOu think its ok for WhompinWedge to have a B1 head...but SSR cant?? Or shouldnt?? Just trying to learn all this geriatric NSS racing stuff
