Quote: Oh boy! Another 413 food fight! I can talk about motorhome 413's because I've got one and built it nearly 30 years ago. Here's a short list of things I pitched when I got my motor home 413:
Heads got swappped for 440 items. Intake from Weiand. Couldn't use the cam or even the cam sprocket because the MH 413 version I had used a gear driven cam that turned backwards. Rockers and pushrods. Water pump and housing. Balancer. Oil pan. Distributor and drive gear. Pistons. Exhaust manifolds.
Even little nit-noid brackets and bolts didn't fit. In other words, I had to nearly buy a complete 440 just to get the parts to put the MH 413 into a car. And in the end... I had a 413... down on cubes from a 440. So... that's the deal. If I had to do it over again today... I'd go for a stroked 400. Just me.... The OP mentions his 413 is coming out of a car. He's still going to have to upgrade to 440 specs... and... it's still going to be a 413.
Greg
Nice mill Greg. Too bad you had problems, those RV mills can some times be trying. Good luck with the 440 man.
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
